OEM Master Gasket Set EVO
Полный комплект всех прокладок и сальников двигателя ориганал, OEM Mitsubishi. В комплект входят следующие прокладки:
MD183240 Gasket, Oil Screen (1)
MD322521 Gasket, Oil Pump Case (1)
MD322522 Gasket, Oil Filter (1)
MN137262 Gasket, Water Pump (1)
MD194403 Gasket, Oil Return Pipe (1)
MD363254 Gasket (1) mastaminds inc.
1226A002 Gasket, Oil Return Pipe (1)
MD329503 Gasket (1)
MR281085 GSKT, Air Outlet Fitting (1)
MD343563 Oil Seal (1)
MD343565 Oil Seal (1)
MD359158 Oil Seal (1)
MD365697 Oil Seal (1)
MD372536 Oil Seal (2)
MR323654 Gasket, Exhaust Manifold (1)
MR299686 GSKT, Exhaust Fitting mastamin(1)
MR404547 Gasket, Turbo Charger (1)
1540A019 Gasket, Intake Manifold (1)
MN155760 Gasket Cylinder (1)
MD041021 O Ring (1)
MD050317 Gasket, Oil Drain Plug (1)
MD075834 O Ring (9) (1)
MF660063 Gasket (10) (2)
MF660064 Gasket Union Nipple (2)
MF660065 Packing, Governor Pipe (4)
MD030764 O Ring, Water Pipe (2)
MD186785 Gasket, Rocker Cover B (4)
MD306079 Seal, Valve Stem In (gray) (8)
MD307343 Seal, Valve Stem Ex (green) (8)
MR497720 Washer Seal (2)
MD340535 Gasket, Rocker Cover, A (1)
Part # 1000A175
Применяемость: Mitsubishi Lancer Evolution VIII 03-05 4g63/4g64 _________________ Powered by Xtreme Garage Odessa
